#1 Posted : Saturday, 15 January 2005 8:42:41 AM(UTC)
whats a good cheap brake upgrade for the old LJ. It's now got to much power for the standards thanks to a supra turbo.
#2 Posted : Saturday, 15 January 2005 10:17:29 AM(UTC)
Will HQ uprights & discs go on an LJ? a la L34/ A9X. If so at least it gives vented 11'discs
#3 Posted : Wednesday, 9 March 2005 7:07:39 AM(UTC)
The LC & LJ brakes can be upgraded to HQ rotors (276mm) and HQ or HX? calipers
by using the drum brake axils from the LC-LJ.
This will change your stud pattern.
If you would like serious stopping power then you could upgrading to
VL turbo disk rot
#4 Posted : Wednesday, 9 March 2005 10:24:17 PM(UTC)
You can also copy the idea used on the LJ Bathurst XU-1 and use HG front discs and calipers, and HK/T/G rear drums and backing plates. This will maintain your current stud pattern. You would also be wise to use a HG brake booster (with LJ rear rod) and ma
