#1 Posted : Thursday, 20 January 2005 3:29:59 AM(UTC)
will a front screen out of a WB Statesman fit into a HQ sedan??
Thank's
Kevin
#2 Posted : Thursday, 20 January 2005 3:42:36 AM(UTC)
Don't quote me on this but i'm about 95% sure that it should fit.
#3 Posted : Thursday, 20 January 2005 4:04:59 AM(UTC)
Yeah mate they do,have bought one before for a hq.They are a nicer looking screen with tint up top and abit down sides from memory.
#4 Posted : Friday, 21 January 2005 2:56:38 AM(UTC)
Hi Guys.
Yes, all the HQ to WB front screens are the same, except for the 2 door coupe (Monaro etc), these are shorter.
The best part about fitting a WB screen is the black band around the outside hides all the dirt & bugs etc that build u
#5 Posted : Friday, 21 January 2005 5:52:41 AM(UTC)
If its an original HQ screen, they were heat sealed. You will need 2 guys, a long wire and patience to get it out. They usually shatter. Cant comment about the WB.
For my $$ and putting it into a GTS/4 I'd rather spend the $$$ and get O'Briens to d
#6 Posted : Friday, 21 January 2005 7:21:26 PM(UTC)
I was told once by a windscreen fitter who was fitting a new screen to my GTS/4 that the only screen available for the HQ-WB series was the tinted around the edges WB statesman screen,which as someone else mentioned looks much better than the original any
#7 Posted : Friday, 21 January 2005 9:16:34 PM(UTC)
Yes Carl, spot on. I had the Premier worked on by Obriens. They had to reseal both screens which had come lose. The front went snap, the rear came out OK. All they had were band tinted ones and looks great! Chrs J.
