#1 Posted : Wednesday, 26 January 2005 10:55:39 AM(UTC)
Hello Ladies and Gents,
I'm now at the airconditioning stage of my HQ ute, what im wondering is would it be possible to install a unit say behind the dash and not have it sitting under the dash.
#2 Posted : Wednesday, 26 January 2005 1:51:36 PM(UTC)
Certainly is Owen. The integrated units from HQ - WB (WB Stato ones are different) will bolt in. However, good luck finding an HQ dashpad with the centre vent in it...you may have to convert yours.
HTH...Dave
#3 Posted : Thursday, 27 January 2005 12:06:40 AM(UTC)
If you sacrificed the glovebox liner& the LHS plunum air inlet. you may be able to fit "hangon" evaporator in that space and then run ducting to the dash vents, and use flexable hose to carry the refrigerant. Just a thought
Webby
#4 Posted : Thursday, 27 January 2005 1:53:00 AM(UTC)
Thanks for that theres several WB's in our local wreckers.
#5 Posted : Thursday, 27 January 2005 4:31:35 AM(UTC)
WB dash won't fit. Ducting is a bit different also.
Make sure you get the switch off the dash, the big vent things that hang down, the control cables,the relays etc off the left side fender, of course the heater box. There are 2 nuts on the inside you ha
