#1 Posted : Sunday, 30 January 2005 11:59:26 PM(UTC)
Is there someone in Aus that is able to fix these or upgrade the mechanisms so they work. Referring to HX model. Thanks
#2 Posted : Monday, 31 January 2005 1:12:58 AM(UTC)
Andrew,
Are these like the HQ ones ? If so they seem to get tired - thats how I'd call it. I have made a few work so far..but it takes time..and they loose/gain a bit per day after being modified.
Cheers, John
#3 Posted : Monday, 31 January 2005 2:45:44 AM(UTC)
Try howard instruments in hiedelberg victoria.
their number is 94574755.
their web site is www.howardinstruments.com.au
#4 Posted : Monday, 31 January 2005 6:36:28 AM(UTC)
I'm not sure what was in the HQ. Interested to know how you got them going. Cheers
#5 Posted : Monday, 31 January 2005 6:40:37 AM(UTC)
Spoke to them some time ago. They were very evasive and weren't sure,would need to look at it etc etc and didnt know if they could do anything. I have heard there is the possibility of replacing the mechanism with digital equipment..
#6 Posted : Monday, 31 January 2005 7:32:34 PM(UTC)
Andrew,
I'll keep it brief. First you need a 12v supply, some leads for same, and connectors for the clock. In most cases, bypass the resistor attached to the 12V on the clock. No go ? Rock it. No go ? Turn it upside down ? No go ? Yes ? If yes let it t
#7 Posted : Tuesday, 1 February 2005 6:33:59 AM(UTC)
If this is the same as a HZ GTS clock then you turn the knob to ajust time and then you pull the knob out and let it go and return as this then activates the vibrating timer. (humming) the other reason they stop is the capacitors dry out over time and nee
