Just wondering would are hj ls coupes rare and would it be worth more if i you kept one original, even if its a 6, as oposed to a blue 308( interior also not original????)
What does the word rare mean? Mitsubishi Colts are becoming rare!
The LS is not as common as a Kingswood. Right now, it is worth as much as you believe it is. Then as much as the money that the next buyer will hand over for it. |
337 made. Of those 81 x L20, 150 x L32, 106 x L31. This makes your 202 HJ LS the second rarest of any particular Monaro combination. Only a manual HQ GTS350 sedan is rarer at 54. |
Byron or Warren was wondering if you could supply a break down of HQ Monaro numbers if at all possible.
Cheers Leroy |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
402 hq gts 350 coupes....206 muncie 4 speed cars and 196 t400 cars...i cant find the rest of the numbers byron gave me but i was only interested in 350 cars so its up to byron for the rest |
byron, any idea of how many factory HX 5.0 T400 Premiers were made?
No. Only breakups I have are for Monaros, which is based upon either Ben Stewart manually counting them off GMH microfiche or from Holden published figures or in the case of HK-HG, based upon engine numbers/ID plate data collected. As far as 5.0L HX Prem |
