7 Pages<12345>»
Sandman Offline
#41 Posted : Saturday, 25 March 2006 7:51:55 AM(UTC)
Sandman
I couldn't be dead sure what model camira. I just went to a camira wreckers and picked 2 out. ($35 each, bargain) They've got steel shrouds. If you happen to see any airconditioned ones, they have 5 blade fans which would probably be better than mine. If
Sandman Offline
#42 Posted : Saturday, 25 March 2006 7:51:55 AM(UTC)
Sandman
I couldnt be dead sure what model camira. I just went to a camira wreckers and picked 2 out. ($35 each, bargain) Theyve got steel shrouds. If you happen to see any airconditioned ones, they have 5 blade fans which would probably be better than mine. If th
classic oz wreck Offline
#43 Posted : Saturday, 25 March 2006 9:19:08 AM(UTC)
classic oz wreck
steel shrouds were jb camira from memory..
www.classicozwreck.com.au
#44 Posted : Saturday, 25 March 2006 7:00:08 PM(UTC)
The WB 4 row has less cores but its bigger, and a crossflow actually cools better than a top to bottom, well in theory anyway.
#45 Posted : Saturday, 25 March 2006 7:00:08 PM(UTC)
The WB 4 row has less cores but it's bigger, and a crossflow actually cools better than a top to bottom, well in theory anyway.
gunna Offline
#46 Posted : Saturday, 17 February 2007 8:04:24 AM(UTC)
gunna
gday there, i also have a 454 thats going into my LE monaro. the motor will be running mainly lpg. it has an edelbrock performer and im wondering if i can avoid using a bonnet scoop. my car has factory air con and would the 454 clear the firewall and air
gunna Offline
#47 Posted : Saturday, 17 February 2007 8:04:24 AM(UTC)
gunna
gday there, i also have a 454 thats going into my LE monaro. the motor will be running mainly lpg. it has an edelbrock performer and i'm wondering if i can avoid using a bonnet scoop. my car has factory air con and would the 454 clear the firewall and air
Sandman Offline
#48 Posted : Saturday, 17 February 2007 7:25:38 PM(UTC)
Sandman
BBC will hit the factory aircon. It will clear everything else though except maybe the fuel pump. You can just squeeze them in with a little grinding using a manual streering box, no chance with a power steering box though.
If you modify the aircon box i
gunna Offline
#49 Posted : Sunday, 18 February 2007 8:49:10 AM(UTC)
gunna
cheers sandman,i thought the air con was going to be a minor hassle but its full steam ahead.with regards to the fuel pump i am going electric anyway.i have power steering,are there any clearance issues to the block? with the air cond everyone knows that
Sandman Offline
#50 Posted : Sunday, 18 February 2007 9:09:31 PM(UTC)
Sandman
I won't be back in town for a coupla weeks, but when I get back I'll try to remember to go see a mate of mine that has 454 with factory air and take a couple of pics of his mods if you like.
I run A9X scoops. While I guess they're not the most trendy or
Sandman Offline
#51 Posted : Sunday, 18 February 2007 9:09:31 PM(UTC)
Sandman
I wont be back in town for a coupla weeks, but when I get back Ill try to remember to go see a mate of mine that has 454 with factory air and take a couple of pics of his mods if you like.
I run A9X scoops. While I guess theyre not the most trendy or bes
gunna Offline
#52 Posted : Saturday, 10 March 2007 10:20:04 AM(UTC)
gunna
i just spoke with an engineer regarding my big block conversion (hx)and he states that wb bracing as well as wb 1 tonner stub axles are mandatory.apparantly they are stronger(nickol content).
gunna Offline
#53 Posted : Monday, 12 March 2007 4:03:44 AM(UTC)
gunna
gday there,in regards to fitting a big block in my hx does a hei dizzy fit(firewall clearance)? also what seems to be the go for carby size in relation to a mild 454/ t700/ salsbury 3.08. dont see a need for 9 inch at this stage due to not being a total r
#54 Posted : Monday, 12 March 2007 4:32:28 AM(UTC)
How are you going to pass ADR27A compliance with a 454 in a HX? I know it's possible, but not easy. I've looked into it in my HZ Overlander and if I do go that way i'm very lucky as 4WD commercials in early 1978 were not required to comply with ADR27A. Th
#55 Posted : Monday, 12 March 2007 4:32:28 AM(UTC)
How are you going to pass ADR27A compliance with a 454 in a HX? I know its possible, but not easy. Ive looked into it in my HZ Overlander and if I do go that way im very lucky as 4WD commercials in early 1978 were not required to comply with ADR27A. The E
gunna Offline
#56 Posted : Monday, 12 March 2007 9:29:58 AM(UTC)
gunna
i take on board what you say byron but i dont mistreat my cars and as for compliance i will go down the road of doing it legal. the car will be running mainly lpg so it will be presented as a straight gas car then mabe revert to dual fuel. i knew a guy so
#57 Posted : Monday, 12 March 2007 4:35:12 PM(UTC)
I agree. Also didnt realise you were intending dedicated LPG.
On the gearbox front, I recently looked into replacing my TH400 in my Overlander with a 4spd. Did a lot of reading on the web. You can buy a TH700 that is beefed up sufficiently to be able to
#58 Posted : Monday, 12 March 2007 4:35:12 PM(UTC)
I agree. Also didn't realise you were intending dedicated LPG.
#59 Posted : Monday, 18 June 2007 10:18:16 AM(UTC)
hi guys im just wondering what i need to do to put a 350 chev into a hj tonner and what do i need to do to keep it leagle will it pass rego do i have to change the diff what about pollution gear im running on petrol do i need a enginneer help wanted thank
#60 Posted : Monday, 18 June 2007 6:10:15 PM(UTC)
Hi Byron.
The Holden Suburbans had 4L80-Es.
The 6L80-E has only been on the US market since the 04 or 05 model year.
Dr Terry.
Guest (20)
7 Pages<12345>»
This page was generated in 0.113 seconds.
