#1 Posted : Saturday, 12 February 2005 5:47:27 AM(UTC)
This may be a simple question for some of you.
I am putting in a Borg Warner diff into the Torana and plan on getting Commodore stud pattern all around.
As I will be putting the diff in soon I will need a pair of wheels for it, preferably 15 inch.
Do all Commodore wheels have the same stud pattern?
#2 Posted : Saturday, 12 February 2005 9:24:28 AM(UTC)
Yes, except for the 4cyl Starfire 4 VC and VH models, they ran a Torana pattern would you believe! They were fitted with 13 inch wheels also unlike other Commodores.
Peter
#3 Posted : Saturday, 12 February 2005 9:25:44 AM(UTC)
Yes, all Commodores have a 5 stud, 120 mm Pitch Circle Diamter stud pattern.
VT2 or VX onwards (not sure about VT Series2) have a larger centre hole bore so should not be used on earlier axles.
HTH...Dave
