#1 Posted : Monday, 21 February 2005 5:16:37 PM(UTC)
Removing the resistor permanently will usually get it going. But as there's no teeth or missing teeth. Hmmmmmm. Flexdrive used to make em I think, and they used to be in Sydney. But that was 20y ago. Maybe EBay for another clock ?
Rgds John
#2 Posted : Monday, 21 February 2005 6:40:00 PM(UTC)
What model GTS is it. For my Q I used the internals from a Gemini TD/E ( can't remember which ) The internals were almost identical,and I swopped the dial and hands ( again I can't recall the details)The clock is still going strong after 7 odd years
#3 Posted : Monday, 21 February 2005 11:52:49 PM(UTC)
Took the advise of earlier trouble shooting of gts clocks. Wasn't working, so changed out resistor with new one. It worked for half a minute then stopped. Had seized up, ended up pulling clock down to show all cogs and found that the one that runs of the drive cog to metronome? gear ( plastic to steel one with 5 or six teeth ) is missing some teeth and some are bent over. Does any know if there are replacement parts or should i just throw it away and get another.
#4 Posted : Tuesday, 22 February 2005 6:34:24 AM(UTC)
HQ, thanks for that i will give it a try.Cheers
#5 Posted : Tuesday, 22 February 2005 7:15:52 AM(UTC)
Sorry to hear about your dramas. I guess Iwas lucky with mine... There is a place in mulgrave, Vic that will supply a change over clock fully recoed for $160. I enquired when mine wasnt going but was reluctant to pay that much. Let me know if you want the
#6 Posted : Tuesday, 22 February 2005 12:49:33 PM(UTC)
If you happen to find the name that would be great. Not sure if I'm prepared to pay that sort of money when I have a VDO clock sitting in the shed. But if we want things original and e-bay doesn't show anything in the near future, and the Gemini option do
