Removing the resistor permanently will usually get it going. But as there's no teeth or missing teeth. Hmmmmmm. Flexdrive used to make em I think, and they used to be in Sydney. But that was 20y ago. Maybe EBay for another clock ?
Rgds John
What model GTS is it. For my Q I used the internals from a Gemini TD/E ( can't remember which ) The internals were almost identical,and I swopped the dial and hands ( again I can't recall the details)The clock is still going strong after 7 odd years
Took the advise of earlier trouble shooting of gts clocks. Wasn't working, so changed out resistor with new one. It worked for half a minute then stopped. Had seized up, ended up pulling clock down to show all cogs and found that the one that runs of the drive cog to metronome? gear ( plastic to steel one with 5 or six teeth ) is missing some teeth and some are bent over. Does any know if there are replacement parts or should i just throw it away and get another.
HQ, thanks for that i will give it a try.Cheers
Sorry to hear about your dramas. I guess Iwas lucky with mine... There is a place in mulgrave, Vic that will supply a change over clock fully recoed for $160. I enquired when mine wasnt going but was reluctant to pay that much. Let me know if you want the
If you happen to find the name that would be great. Not sure if I'm prepared to pay that sort of money when I have a VDO clock sitting in the shed. But if we want things original and e-bay doesn't show anything in the near future, and the Gemini option do
