#1 Posted : Tuesday, 22 February 2005 1:04:13 AM(UTC)
i am putting a new cd player into my car and on the connection in the back of the old one the wires are from 1-14. can ne one tell me what numbers go with which wires. eg (power, battery, left and right speakers) etc.
#2 Posted : Tuesday, 22 February 2005 1:42:57 AM(UTC)
What model - F, E, H series ??
(1) speakers. Does it have them now ? If so look at the colour on the speaker cables. (2) get a multimeter, or make up a 12V test lamp. (3) for the +12V its usually red. the volts will be there all the time. (4) for ACC t
#3 Posted : Tuesday, 22 February 2005 6:14:24 PM(UTC)
I never bother with numbers, it is the colours that matter.
There should be a red wire that will connect to a positive, on old cars you could connect this to the radio fuse or the horn fuse if you want your friends to access the radio when the key is
#4 Posted : Tuesday, 22 February 2005 9:49:39 PM(UTC)
On some older systems you will find one green wire, one grey wire and a black wire for the speakers.
The black wire is to be connected to the negative of both left and right speaker wires.
s
