#1 Posted : Monday, 28 February 2005 4:22:30 AM(UTC)
are these just a straight forward bolt up to a kingswood, or do you need the GTS wiper motor as well?
#2 Posted : Monday, 28 February 2005 5:18:47 AM(UTC)
You need the special dash extension thing the diecast frame of the dash is in 2 pieces, one of which has a fitting cast into it that the control goes on to.
#3 Posted : Monday, 28 February 2005 8:01:05 PM(UTC)
These are a aimple bolt in item. When you pull the dash apart you will see the controller and a black box in the wiring. Two white wires will go to the wiring in the Premier/GTS/Statesman.
Unplug the white wires in your Kingswood and plug the controll
