#1 Posted : Thursday, 10 March 2005 8:07:04 AM(UTC)
gday will a vk injected inlet manifold fit on to a red motor head being 12 port
any help would be great
thanks dave
#2 Posted : Thursday, 10 March 2005 6:46:07 PM(UTC)
No. But it's not hard to fit an injected motor head onto a red motor. Just lay a blue/black head gasket onto the top of the red motor and drill out the three (possibly four) water jacket holes that are required. The red motor ones get blocked off by the g
#3 Posted : Thursday, 10 March 2005 8:36:33 PM(UTC)
I did up a 186 Red that i just put a 12 port head onto, and had a VK injection menafold with straight gas. It was very sweet.
#4 Posted : Sunday, 13 March 2005 1:47:35 AM(UTC)
thanks for your help guys
#5 Posted : Tuesday, 15 March 2005 6:22:48 AM(UTC)
#6 Posted : Tuesday, 15 March 2005 8:11:12 AM(UTC)
There won't be a computer if on straight gas. The VK EFI ran a blue motor style HEI dizzy. Only the EST carburetted engine had an ECU controlled ignition.
#7 Posted : Wednesday, 16 March 2005 7:34:29 AM(UTC)
#8 Posted : Wednesday, 16 March 2005 7:21:01 PM(UTC)
Unless it was dual fuel there would be no need for the ECU, injectors etc. Gas will be metered by the regulator and donut mixer or possibly throttle body. The reason for using the EFI manifold with ram tubes is that it give a 15kPa boost at the inlet valv
#9 Posted : Tuesday, 29 March 2005 4:54:39 AM(UTC)
What would i need to do with the computer and wiring to fit on a vh 173 with a super charger.( its hard to get info on this sort of stuff so it would be greatly appreciated)
#10 Posted : Tuesday, 29 March 2005 5:35:43 AM(UTC)
The VK injection hardware will bolt straight onto a blue 173. However you won't be able to use the factory computer. It's an old analogue piece of crap. You can make a VN Delco ECU work, but the hardest thing is getting the sensor in the back of the VN ha
#11 Posted : Tuesday, 29 March 2005 7:06:27 PM(UTC)
Can i use the standard vk computer on a non supercharged 173? or is it worth buying a vk injected and putting my motor in it. and can i use the same extracters?
#12 Posted : Tuesday, 29 March 2005 7:27:26 PM(UTC)
It might work, but the 173's fuel requirements might be below the 'programmed' window of the ECU. The VK setup uses an air flap air flow sensor, so it won't open as far with a 173. All of the stuff should fit easily into the VH engine bay as VB-VK are bas
#13 Posted : Tuesday, 29 March 2005 7:48:05 PM(UTC)
Thanks Byron.
666 Offline
#14 Posted : Tuesday, 29 March 2005 11:22:31 PM(UTC)
666
Byron,
When u say the hardest thing is to install the sensor on the harmonic balancer, couldn't u just change the flywheel on the carburtated vk and use the sensor in the bellhousing instead ? (just a thought).
Kev
666
666
#15 Posted : Wednesday, 30 March 2005 12:21:37 AM(UTC)
You may be able to do that, but remember the EST engine (carby VK) has three dowels around the flywheel at 6 degrees BTDC, one for for each pair of cylinders. It is simply used for spark control. The engine still has a distributor, which really does bugge
#16 Posted : Wednesday, 30 March 2005 8:52:37 AM(UTC)
The EST system was nothing to write home about most people converted to electronic ignition for more reliability.
Guest (6)
This page was generated in 0.092 seconds.
