RJR Offline
#1 Posted : Thursday, 17 March 2005 6:26:09 AM(UTC)
RJR
Hi guys just like to know the comparison on the fuel consumpion between the 350 and the VS V6 in an FJ thanks
#2 Posted : Thursday, 17 March 2005 10:12:16 PM(UTC)
You might as well ask 'how deep is the ocean', 'how far away is neptune', or 'how long is a piece of string'. I challenge anyone to sensibly answer your question. More useful info is needed...
I can tell you that my 2000 model VS series III ute (V6 man
#3 Posted : Friday, 18 March 2005 5:17:48 AM(UTC)
V6 would be alot less fuel ussage than 350.
3.8l vs 5.7l
injection vs carby(maybe, depends which 350)
modern vs older
etc
etc
DO NOT WRITE BELOW THIS LINE
RJR Offline
#4 Posted : Sunday, 20 March 2005 7:15:22 PM(UTC)
RJR
thanks guys i will stick with a V6 now so have to decide on which one, I was told the VS Series 2 and tranns, this FJ has the ford 9" diff with 275cm rims on rear would that need to be changed also, the car was used for Drag racing by previors owner,I jus
#5 Posted : Sunday, 20 March 2005 10:00:23 PM(UTC)
Depending on how good you are with electrics, the VN2 or VP V6 and T700 (rather than the electronic box from the VR on) will be MUCH easier to wire up. From VR on, you will need to get around a much better security system. It can be done, but is more work
