#1 Posted : Sunday, 20 March 2005 6:23:30 AM(UTC)
Hi All
Have just finished putting in a supra box in my ek (hydraulic clutch, new pressure plate and clutch plate) and have a problem. It changes gear fine when the motor/car is cold, ie just after you start to drive, but after about 15 minutes, it grinds when changing. it doesnt seem to disengage enough, so am wondering if anyone had any ideas. I have flushed the clutch, put in new fluid and have bled it. is there perhaps still air in the clutch? Or could it be something else?
#2 Posted : Sunday, 20 March 2005 7:25:33 AM(UTC)
If you can, check that your throw out bearing is free and has a little movement between the bearing face and your pressure plate fingers. you should be able to feel a bit of slack in your clutch pedal.Sounds like you are engaged a bit. Is there any adjust
#3 Posted : Sunday, 20 March 2005 9:37:22 AM(UTC)
Cammo,
It seems you do not have enough travel at the clutch fork end of things. When everything is cold, it works OK and JUST disengages the clutchplate from the pressureplate (maybe the clutch slips a bit when cold as well?) but as the bits heat up a
#4 Posted : Sunday, 20 March 2005 9:41:04 AM(UTC)
Sorry, forgot to add one other bit...
Does your clutchfork pivot on a ball that screws into your bellhousing? If it does, you may be able to fix your problem (at least temporarily) by "undoing" the pivot to move it towards the front of the car and then
#5 Posted : Sunday, 20 March 2005 12:44:17 PM(UTC)
yeah, the pedal is a fair bit lighter and i am running the original slave and master cylinder. The fork only has a hole on the outer end and I have adjusted the pushrod, but will try and adjust the pivot next.
Thansk for the replies.
