#1 Posted : Monday, 21 March 2005 12:37:28 AM(UTC)
i have a 5.0litre vp ex-police,the computer is original delco & delco memcal,i'm hoping someone can verify for me the specs of the memcal as holden dealer's have no info,the only info they have is my car is 92 model,5.0,auto but it's a 6th month 1993 model,5.0,auto.i took memcal out of computer and it's number is BAAP and want to verify if it's a 160kw,180kw or whatever size it is if that's appropriate.i also want info on where i can get this chip re-calibrated if it can be or buy a maximum size memcal for my model.
Taz2 Offline
#2 Posted : Monday, 21 March 2005 5:27:53 PM(UTC)
Taz2
http://www.geocities.com/memcals/vncals.html
BAAP???? $FB 92, 5.0L V8 Auto 1227808 Production 92mdl V8
Edited by user Monday, 21 March 2005 5:29:36 PM(UTC)  | Reason: Not specified
In thrust we trust
#3 Posted : Tuesday, 22 March 2005 2:41:14 AM(UTC)
unless you have some mods done to it (a minimum of full extractor/exhaust system, high flow air filter and cold air intake) it is not worth getting your car rechipped.
a 180kw chip will not make a standard car have 180kw.
powerchips that are sold of the
#4 Posted : Tuesday, 22 March 2005 3:48:57 AM(UTC)
Hi Guys.
Taz2 is correct, the BAAP mem-cal is for 92/93 std 5.0 Auto. The 180kW HSV/Police memcal you were asking about is BBMP.
As tockley says, it's useless putting the 180 kw in a std 165 kW car, you will end up with LESS that 165 kW.
The 'Ch
#5 Posted : Wednesday, 23 March 2005 4:08:58 PM(UTC)
THANKS BOY'S,but i still don't know if it's a 160kw chip or 180kw is there anyway of knowing the kw size without getting it dyno'd.i've just put gts extractor's i got with the car and changed them over from stock exhaust manifolds,then had two three inch
#6 Posted : Wednesday, 23 March 2005 5:45:14 PM(UTC)
It was 165kw. As you removed stock exhaust manifolds, that's the dead giveaway.
180kw motors had extractors on them.
Also, have a look on each side of the block, right near the engine mounts - do you have a pair of coolant drain plugs (1 on each side
#7 Posted : Thursday, 24 March 2005 4:35:38 AM(UTC)
Hi again tockley.
Didn't I say in my post, that your BAAP mem-cal was for a std 5.0 auto.
By std I meant 165kw. Sorry for confusing you.
Dr Terry.
#8 Posted : Sunday, 27 March 2005 12:36:47 PM(UTC)
thanks heaps fella's you's have definately cleared up my questions with what i have to play with and verified a few myth's as to the questions i posed,don't get me wrong i'm mechanically versed as to having two brother inlaw's whom are mechanics and using
This page was generated in 0.435 seconds.
