#1 Posted : Monday, 28 March 2005 8:45:05 AM(UTC)
Hi Guys,
Does anyone know if the HQ and the HJ front chassis and suspension setup are the same. What Im getting at is could I take all the front suspension hardware and put it onto the HJ front chassis without changing anything.Thanks
Owen.
Dylan Offline
#2 Posted : Monday, 28 March 2005 9:49:12 AM(UTC)
Dylan
yes, straight swap, the suspension didnt change untill late HX when RTS was introduced
#3 Posted : Monday, 28 March 2005 8:40:29 PM(UTC)
Thanks for the info, Its great news knowing the HQ and the HJ are the same. Again Thanks, Cheerio Owen.
Taz2 Offline
#4 Posted : Tuesday, 29 March 2005 4:06:51 PM(UTC)
Taz2
Dylan is spot on.
I assume you have an HJ and therefore want to use that subframe. However if you can obtain an HZ RTS subframe, you will have better handling, and once again it is a straight swap over.
In thrust we trust
