#1 Posted : Friday, 1 April 2005 3:07:40 AM(UTC)
hey fella's i just got an xf with a 250 x-flow and was wondering what is the cheapest/most effective way of giving it a quick power boost
#2 Posted : Friday, 1 April 2005 4:13:01 AM(UTC)
extractors and a good 2 1/2 inch exhaust.if you aint got the money for a new set of extractors (round $350) get a second hand set otta the trading post ebay etc (round $50) will cost a round $300-$400 for the system to be fitted.make sure you get free flo
#3 Posted : Friday, 1 April 2005 4:54:04 AM(UTC)
thanks "tuff 250" i appreciate all the help i can get on this, so if any one else has any other ideas i would love to hear them
#4 Posted : Friday, 1 April 2005 7:10:01 AM(UTC)
Check your alloy head. On the inlet side at the front there may be a stamp C1 or C2. These are higher compression heads (C2 especially) that should give better performance.
#5 Posted : Sunday, 3 April 2005 2:11:35 AM(UTC)
Run your XF on higher octane fuel as well. this will also help clean the motor out a lil, and make it a bit more responsive. Ie Bp Ultimate, Caltex Vortex - both are 98 octane, whereas regular unleaded is 91 Octane.
If its a preunleaded motor, you can st
#6 Posted : Sunday, 3 April 2005 9:10:02 PM(UTC)
Actually dude ry running your car on optimax with nulon octain booster the fuel strength additive.advance you timing.if it is a carbi engine replace the carbi with a 350 holley or if the carbi on yur engine is a ute carbi.the ute carbi ones,the butterfly'
