#1 Posted : Monday, 4 April 2005 3:28:55 AM(UTC)
I have bought a cheap VH wagon , running a 253 HQ motor, the motor runs slightly rough and under load blows white /grey smoke which I would think was water in the system? theres no milky sludge under the breather cap and the dipstick oil looks normal.
Could it be the inlet manifold badly corroded ?
any thoughts...
#2 Posted : Monday, 4 April 2005 3:47:30 AM(UTC)
if its coming out the exhaust it must be getting into the combustion chamber rather than the sump. if a valley cover leaks into the valley it will milk up the oil but wont make it out the exhaust. i would be doing a compression test and checking the plugs
#3 Posted : Monday, 4 April 2005 7:36:13 AM(UTC)
Does the smoke disappear quickly or hang around? If it disappears quickly it is most likely steam which means a head gasket etc, if it hangs around it is probably oil means rings or valves.
Also try putting a rag folded several times over the exhaust for
#4 Posted : Monday, 4 April 2005 6:16:20 PM(UTC)
it doesn`t hang around and nothing at idle , I`ll do comp test and see what comes up.
cheers guys.
#5 Posted : Tuesday, 5 April 2005 1:08:14 AM(UTC)
253's from experience ( I have 2 of em) blow white smoke/steam only when cold or warming up. And it can be quiet a deal of it.
However when the engine is warm ! There should be none.
Cheers, J
#6 Posted : Tuesday, 5 April 2005 3:30:42 AM(UTC)
Hi Guys.
If it blows smoke under load it's most probably rings. The colour of the smoke is not a good indicator these days.
If you are concerned about water/head gasket issues, get a chemical test, very quick & cheap.
Are you actually using much
#7 Posted : Tuesday, 5 April 2005 5:15:33 AM(UTC)
I haven`t been driving it around only up the street for a test , I originally bought it for parts and knew the motor had problems of some sort.Thanks for the help , I have passed on the info from you guys to my nephew who has offered to buy the car from m
This page was generated in 0.112 seconds.
