#1 Posted : Tuesday, 5 April 2005 6:12:16 AM(UTC)
after putting 17 inch weels on my vn did 100kms and now the rear makes scraping noise with a slight clunkin also if i go slow and in reverse it sounds normal. at the same time changing the weels i also changed a rear disc rotor. i pinpointed the noise were the tailshalft meets the diff i think,i was restricted to room tho. it has a solid lsd diff, and super lows. noise started wen i turned off a main road at 80kmh the tyres were scrapin wen i had extra passengers aswell.
Taz2 Offline
#2 Posted : Tuesday, 5 April 2005 3:47:29 PM(UTC)
Taz2
I'd say that if you have put super low springs in, you need to get an adjustable panhard rod to realign the rear end.
I have King super low springs in my VN, and apart from using an adjustable panhard, the guards at the top had to be rolled slightly.
I'
In thrust we trust
#3 Posted : Wednesday, 6 April 2005 3:13:54 AM(UTC)
Hi Guys.
It's quite common on these models for the rear uni or yoke to foul the muffler in front of the axle, especially when they're lowered.
Dr Terry.
#4 Posted : Friday, 8 April 2005 4:37:54 AM(UTC)
hey chears guys, problem solved. i did the uni joint so ill fix it this weekend so i can get those gaurds rolled next week
