#1 Posted : Thursday, 21 April 2005 6:26:41 AM(UTC)
Can any help me. I want to fit a WB stato rear bar onto the rear of my HZ ute but the brackets dont fit. apparently I can get brackets made or use other holes. Anyone with ideas.
Holdenute Offline
#2 Posted : Thursday, 21 April 2005 6:58:30 PM(UTC)
Holdenute
Hi Tim,
You need to get brackets made. They'll use the rear holes, but not the side ones. Hope that makes sense.
When I put mine on I was lucky enought to find a set at a PicknPull wreckers. Carry a camera with you and next time you see a ute with a
Never late in a V8
#3 Posted : Thursday, 21 April 2005 11:56:14 PM(UTC)
Hi Tim,
Are you sure that you will still be able to open your tail-gate when you have the WB Stato bumper on there? I believe that you have to use an HQ-HZ wagon rear bar as they are slightly less wide aand therefore have enough clearance for the tailg
#4 Posted : Friday, 22 April 2005 7:06:27 AM(UTC)
Thanks guys pics would be good. I didnt actually know about the clearance on the tail gate so I will ask some questions with some mates before I go ahead with it.
Tim
#5 Posted : Friday, 22 April 2005 8:15:09 AM(UTC)
mate i did this not so long ago & had to make brakets for a wagon bar to fit up , i raded the thick rubber from a bar that was damaged & fitted it up ! my advice is to start ringing the wreckers to find one allready done !
do you have hq gts stuff 4 me
Intoit Offline
#6 Posted : Monday, 25 April 2005 8:54:45 PM(UTC)
Intoit
Tim ,
I have some pictures of the brackets & the new holes in the ute . When I had my HX it already had a full rear bar fitted . Contact me through my profile if you would like me to send them to you
Cheers ,
Shawn
--------------------Go Hard Or Go Home
#7 Posted : Sunday, 1 May 2005 7:06:01 AM(UTC)
I also have a wb rear bar on my hz van. I modified the wb brackets to fit the van.
