#1 Posted : Saturday, 23 April 2005 1:56:17 AM(UTC)
Hi guys
Some years ago now I bought new window channel seals but since replacing the old ones the windows don't go all the way up, there's a slight gap which gets annoying on long drives. I can't work out why it won't go up fully so I wondered if anyone here has any ideas?
These are ute doors by the way
thanks
Andrew
#2 Posted : Saturday, 23 April 2005 8:27:37 AM(UTC)
Sometimes a relief cut is needed in the bailey channel rubber on each bend so that the channel rubber doesnt restrict the glass going up. I had this prob too. Otherwise adjust the 2 frames that guide the glass runner. Not so hard to do. They have to be ad
Taz2 Offline
#3 Posted : Saturday, 23 April 2005 4:57:47 PM(UTC)
Taz2
Be careful not to force the windows up until you fix the channel problem, or you will quickly wear out the teeth on the winder mechanism.
Trubluhq's remedy is pretty well spot on....I've also had the same problem when new channel is fitted.
In thrust we trust
