KiwiHQ Offline
#1 Posted : Thursday, 5 May 2005 1:35:16 AM(UTC)
KiwiHQ
Hi there,
new forum is great. I have a HQ with a 3 speed manual on the tree. Looking at buying a HZ indicator stalk so i can use the window wipers on the stalk. Question is; can i buy just the stalk and does it just bolt in/on or is it easier to get the stalk with the sleeve as well and just swap it in?
Brian
Rock n Roll
#2 Posted : Thursday, 5 May 2005 4:03:31 AM(UTC)
Hi Brian,
I have done this conversion a couple of times, once into the original column in an LJ and once where I changed the whole column in an HQ. You will need the upper column jacket as well as the later indicator switch and you will need to do a bi
#3 Posted : Thursday, 5 May 2005 10:42:34 PM(UTC)
Does anyone know what the wiring differences are. I have a WB column I plan to put in the HQ as the HQ one is pretty average,
cheers,
Scott
#4 Posted : Friday, 6 May 2005 3:01:34 AM(UTC)
It is an easy conversion using HX/HZ/UC parts, but WB (and Commodore) is a bit more difficult. The difference is the reversing lights. WB and Commodore (not sure if this applies to all VB Commodores) have separate reversing lights, and these are controlle
#5 Posted : Friday, 6 May 2005 3:35:13 AM(UTC)
Hi Guys.
I've done this conversion a few times, & I've just left the blinker switch intact & changed the stalk only. Then you only have to worry about the wiper wiring.
You do, of course have to cut the larger square hole for the wiper switch type s
Intoit Offline
#6 Posted : Friday, 6 May 2005 6:09:15 AM(UTC)
Intoit
Hi ,
Byron & Dr Terry are 100% correct . But , correct me if I am wrong but when the VB , WB came along they changed the colour code . Holden basically carried the same c/code through all models till then .
--------------------Go Hard Or Go Home
#7 Posted : Friday, 6 May 2005 7:10:16 AM(UTC)
Hi guys,
The colourcoding is different for the wipers (WB Stato column to HQ). The wires are mostly the same colours, but in a different order but this may be dependent on which wiper motor too.
Byron is correct with the indicators, In the HQ column
Edited by user Sunday, 8 May 2005 12:14:57 PM(UTC)  | Reason: Not specified
Taz2 Offline
#8 Posted : Friday, 6 May 2005 4:22:29 PM(UTC)
Taz2
Yep....Daves got it right.
Light blue & yellow BOTH joint to light blue.
Dark green & dark blue BOTH join to dark blue.
I've done this conversion quite a few times a while back. Just couldn't remember which pairs joined into single wires.
Wiper connec
In thrust we trust
#9 Posted : Saturday, 7 May 2005 6:28:31 AM(UTC)
Hi Bruce,
I *THINK* the dark blue from the car joins the the grey wire for the WB Stato wiper switch in the column. Then you need to run a new wire from the dark blue on the column to the washer motor.
I had a quick look at the Qute today, but need
