eskimo_joe777 Offline
#1 Posted : Sunday, 8 May 2005 8:17:40 AM(UTC)
eskimo_joe777
I just brought a VH that has been done up to look like a VK and they put the VK speedo in it and when i am going 100km it shows 75km on the speedo? do they have different gearing in the speedo? is there anything i can do to fix it?
Cheers Justin
#2 Posted : Sunday, 8 May 2005 11:49:04 AM(UTC)
very easy its just a matter of finding the right gear for the bottom of your speedo cable if you go to a speedo specialist they should be able to work out the right one or go to the wreckers grab as many different colours as you can get (different colours
#3 Posted : Sunday, 8 May 2005 11:55:11 AM(UTC)
If you let us know what ratio diff, what size wheels and tyres, whether it is a 6 or V8 and what transmission you are running, someone will be able to tell you which driven gear to use on the end of your speedo cable.
Cheers...Dave
#4 Posted : Sunday, 8 May 2005 11:48:20 PM(UTC)
this may help
http://www.oldholden.com...M21_Catalogue6.sized.jpg
70ute
there are no stupid questions, only stupid people
crowe Offline
#5 Posted : Monday, 9 May 2005 10:48:47 PM(UTC)
crowe
what g/box did the vk have. As only the 5l had aussie 4 speed. all the 6cyl had the toque master 4 and 5 speeds. i ask this as if its only the speedo thats been changed then the existing gearing should be ok. i would think that something in the drive line
#6 Posted : Tuesday, 10 May 2005 4:00:38 AM(UTC)
Hi Guys.
The Torquemaster is only a 4-speed box, the 5-speed in the VH/VK was a Borg-Warner. Also I have come across quite a few Aussie 4-speeds behind 6 cyls in VK, maybe it was a 'special order' option.
Dr Terry.
#7 Posted : Tuesday, 10 May 2005 4:59:49 AM(UTC)
eskimo_joe777
Its a 202 and the guy told me it had a M21 but i recon its only a M20 because the first gear isnt very long but not sure. um the diff is still standard i think.
i will try the cogs like charles said and go from there.
cheers Justin
