#1 Posted : Tuesday, 10 May 2005 6:56:21 AM(UTC)
Hi ppl, new to site and new to restoring vehicles, restoring a HJ ute, auto with a 253 motor, problem is after removing all the rust and not bogging up like previous owner/s, the Ute looks good with new paint etc, but it takes forever to warm up, bit like me I guess, when I put it into gear, fwrd or rev, it stalls under load, am no mechanic, just a reasonable Mig welder and spray painter, want to sell the Ute ASAP, before that I want to make sure she is running right, needs another radiator, saving up for that, any tips on how to fix the stalling problem (besides some c4) will be greatly appreciated.
Cheers and a great site
trubluhq Offline
#2 Posted : Tuesday, 10 May 2005 8:41:57 AM(UTC)
trubluhq
Wazza,
Does it start and run at all ? Have u put a carbie kit thru it ?
What carbie ? Stromy, Holley or Quad/Rochester ? Any A/con or P/steer ?Idle on a bog std 253 auto (no air or p/s) is around 800 in neutral with 500-600 in Drive. With accessori
#3 Posted : Tuesday, 10 May 2005 9:48:31 AM(UTC)
Hi john, no Power steering, aircon, I wish. Has a Holley carby, twin extractors, need to install a tacho for revs, will try increasing idle, is it normal for the 253 to take a long time to warm up b4 driving? (time for a coffee, shower, another coffee, wa
trubluhq Offline
#4 Posted : Tuesday, 10 May 2005 9:38:34 PM(UTC)
trubluhq
Hi Waz, the Holley shouldnt be a problem, two idle mix screws and one throttle screw. Is it a BIG Holley or a little one ? How big at the extractors (2, 2.5 or 3") ?. They wont start doin much till you hit 3000-5000 revs. But a loss of backpressure at low
#5 Posted : Friday, 13 May 2005 6:27:26 AM(UTC)
Thanks John for input, it is a lge Holley, with what looks like 2" extractors, looks like a mechanic will be needed, bugga, no idea on backpressure etc.
#6 Posted : Wednesday, 25 May 2005 4:25:33 PM(UTC)
l had same prob make sure the dizzy advance line is plumbed in direct to the manifold as mine was plumed to the carby as soon as l changed it prob was fixed.
#7 Posted : Saturday, 4 June 2005 6:56:05 AM(UTC)
hey there... i have the same issue with my hr... it is stroked to 225, nas 2 1/2" exhaust and a reasonably lumpy cam, running a 350 holley the idle screw is right in, both mix screws right out, and still stalls in gear at idle... coul dthe dizzy adva
This page was generated in 0.190 seconds.
