Just fitted power antenna from stato to ute (which originaly had manual antenna) hooked up all the wiring, checked fuse O.K and can not get power to antenna is there a extra relay to put in?
Thinking of fitting climate control from stato to ute, has anyone done anything like this???? Would I need to use the stato loom or could I patch it intop the ute loom? would it work with ute BCM, I know I would had to wire temp sensors in somehow
For your climate questions, have a look at this: http://forum.streetcommo...showthread.php?t=8460737If you are really going to that much trouble, you should have just put the stato loom into the ute & modded the rear wiring at the plug in t |
Your probably right in saying I should of done the loom swap, but I wasnt going to put climate in to start of with and then thought why not Ive go a complete doner car- after reading the thread I'll do some more research and have a crack!!!
With the an
Ahhh, you had the 2 pin plug for the aerial?
OK, what you now need, is the power aerial module, part number 92029494.
This same module was fitted from VL to VS, but was not fitted to Berlina & upwards models on VR/VS as the BCM took over that role.
Have hooked it up with power from power antenna fuse and antenna control from my stereo, I think I will try and get the power arieal module and switches though as ariel is too high when fully extended, would of liked to of done a full loom swap but stato
With the loom swap, here's a few points that may help:
1. You don't have to worry about the ABS - if you don't plug the module in (driver's kick panel) you can just leave the connector hanging (but tape up the open side). This is how my VS2 S pack sed |
If I was starting from scratch I would probably go with the loom swap but the only things I want to get going is the climate and steering wheel controls, the only question I have is can I use steering wheel controls with the ute loom, Ive already fitted
Sorry for my stupid question, you already explained that in your answer
I have VR exec and am looking for a pranged berlina or calais to swap accessories to the exec - this time I will definatly do the loom swap, the main reason I didnt do this with the ute was time, laziness and rear of vehicle wiring which In hind sight was
