Hi guys
I have a rusty fuel tank, I bought it second hand and I think the corrosion is pretty bad as it seems to be blocking the fuel filter quite regularly.
HJas anyone any udeas on stopping the rust? I suppose there is no quick fix, it's an HJ ute.
hello richo,the easiest way get a new tank if you can,if it is blocking the filter all the time,cheers gts 082
Hello Mate
I have a friend with a Triumph TR6 that had this problem. He had it fixed by a company that coat the inner walls of the tank with a resin that effectively forms a skin inside the tank. Been perfect ever since.
This may be better than goin
Hi Paul,
A company name and/or location would be good mate...
Cheers...Dave
Hi Guys.
I've seen that product, I think it's called POR 15. They usually advertise it in mags like Australian Classic Car.
Dr Terry. |
Yep. Dr.Terry is correct. The URL is: http://www.ppc.au.com/index.htm
I've done a boat alloy tank in this stuff, and it works brilliantly. |
In thrust we trust |
Hi guys POR tank sealer is the way to go for sure just make sure you use the metal prep first and make sure the tank is completely dry before adding sealer I had same prob on my wgn no probs since. 500ml was more than enough to do tank inside and
