#1 Posted : Friday, 20 May 2005 10:32:18 PM(UTC)
Are the power steering racks adjustable (as in, can you tighten ? If so, is it a simple grub screw like in the recirculating ball types?
#2 Posted : Friday, 20 May 2005 10:35:45 PM(UTC)
Please excuse typo above. I don't seem to ba able to edit posts unless logged in. Speaking of which, is it customary not to be able to log in a week after registering?
#3 Posted : Saturday, 21 May 2005 1:28:06 AM(UTC)
If you adjust on car it is possible to affect the return to centre on the rack. On a kirby rack it should be done with an inch pound torque wrench and an angle guage.
#4 Posted : Saturday, 21 May 2005 3:26:28 AM(UTC)
Sounds like a pain. Any idea how much for a replacement?
Taz2 Offline
#5 Posted : Saturday, 21 May 2005 3:17:53 PM(UTC)
Taz2
Last time I checked Pedders wanted around $450 changeover with them doing the installation.
We sell good cond 2nd hand p/s racks for $250.
In thrust we trust
#6 Posted : Saturday, 21 May 2005 7:22:39 PM(UTC)
Supply & Fit VN rack including wheel alignment should set you back about $420. To ship rack anywhere in Australia, should cost about $300. Let me know if you want more details from me.
#7 Posted : Saturday, 21 May 2005 10:21:19 PM(UTC)
Whoa, that's a bit more than i expected. The reason why I asked is that both VN's I have driven so far have had a bit of play (not too much but a bit, you could hear the click, click, click when rocking the wheel side to side either way when stationary.)
#8 Posted : Sunday, 22 May 2005 3:49:54 AM(UTC)
Most racks will knock in the stationary position. Bearing in mind, this is where the max load is affected on the rack. In the case of a kirby bishop rack, as in your VN it is a variable ratio rack and they do tend to knock a bit more than others. It is
#9 Posted : Sunday, 22 May 2005 10:49:23 AM(UTC)
That's a bit reassuring. Thanks Paul.
Guest (7)
