i have a set of standard GTS wheels that i want to get modified to suit a torana with HQ stud pattern.
what is the correct offset for the torana? what about if i choose to get them widened to 7"?
has anyone here dealed with ajax wheels
Thanks. Dylan
IIRC they L34 and A9X offset was 1" negative as compared to the GTS rims. I used to run A9X running gear (and L34 before that) under an LX Hatch with no flares. 14x7 polycast rims off HJ-HZ GTS and LE were the perfect offset for car BUT the seam on the f |
can't help with the offset question but have dealt with ajax for 10years or so and they are great cheers Ted
