3 Pages123>
#1 Posted : Saturday, 18 June 2005 6:21:00 AM(UTC)
Hi,
Just filled up with Octimax (my usual fuel), and suspect it may have water in it... I'd like to try the "metho" remedy. How much metho should be added to a full 55L tank? I'm guessing about a cup won't hurt, but will it do the job?
Any advice from those who have tried it?
Jason.
RussVRute Offline
#2 Posted : Sunday, 19 June 2005 2:32:25 AM(UTC)
RussVRute
A cup is fine, maybe even 2 ,I used to use half a cup in my motorbike and that only holds about 10-12 litres, and yes it does work, dissolves the water into the fuel, also boosts your octane slightly, but not enough to make much difference.
Russ
Jim Briar Hill Offline
#3 Posted : Sunday, 19 June 2005 6:39:47 AM(UTC)
Jim Briar Hill
Hi Jason you can go upto and above 1-4 1part metho to four parts fuel but a bottle will do the trick ( 500 ml ) have seen 50 - 50 mix on really bad fuel but also shot flames ( not to good for the paint ) Cheers Jim
Edited by user Sunday, 19 June 2005 6:40:26 AM(UTC)  | Reason: Not specified
#4 Posted : Sunday, 19 June 2005 6:55:55 PM(UTC)
Thanks Russ and Jim - I will give it a shot and see how it goes.
Jason.
gts082 Offline
#5 Posted : Tuesday, 21 June 2005 2:52:05 AM(UTC)
gts082
try next time the new fuel vortex 98octane(caltex),i use it in my hq & vy,fill the difference,cheers.
#6 Posted : Tuesday, 21 June 2005 9:17:03 AM(UTC)
Actually I *have* been recommended to move to BP Ultimate, or Caltex Vortex, instead of Optimax, because Optimax has a shelf life of 28 days after manufacture. Ultimate and Vortex supposed to be a fair bit longer. Takes me 2 months or so to go through a
#7 Posted : Tuesday, 21 June 2005 11:48:28 AM(UTC)
BP is the way to go if you have any problems with water they dont argue about paying for repairs and there pumps are calibrated often I know because I have a mate that repairs and calibrates there pumps
If all drivers were enthusiasts there would be le
#8 Posted : Friday, 24 June 2005 10:17:17 AM(UTC)
You guys are talking about metholated spirits right?
how does that disolve water in the tank? I had no need for my flashlube bottle anymore so I filled it 50/50 water and metho, with more metho can I get these flames? sounds cool! hopefully without engi
#9 Posted : Saturday, 25 June 2005 3:25:29 AM(UTC)
Hi Guys.
The problem with water is that it won't mix with petrol & stays in separate 'lumps' & when it collects in your carby it causes corrosion if it stays there too long. If it would mix with the petrol it would be a form of water injection right. I
#10 Posted : Saturday, 25 June 2005 8:02:59 AM(UTC)
Hi Dr Terry,
I thought that ethanol was not good for older cars in that it rusts metal fuel tanks and corrodes aluminium carbies?
Cheers...Dave
#11 Posted : Saturday, 25 June 2005 12:54:05 PM(UTC)
Hi Guys, please advise if this seems fuel related: sometimes after I fill up with LRP the old 186 pings like no tomorrow and leaves a smokescreen worthy of the Batmobile on take-off. Most times the engine is basically smoke-free and needs a fair bit of pe
witcheshollow racing team Offline
#12 Posted : Sunday, 26 June 2005 7:57:37 AM(UTC)
Well Dr Terry, you have done it again ! I have heard all the hype about ethanol and seen the signs go up everywere saying "NO ETHANOL" But I never new metho was ethanol and I remember that being the number one cure for a car with crook fuel, one cup of m
"Such is life"
#13 Posted : Sunday, 26 June 2005 3:11:51 PM(UTC)
#14 Posted : Monday, 27 June 2005 7:09:19 PM(UTC)
trubluhq Offline
#15 Posted : Monday, 27 June 2005 8:36:12 PM(UTC)
trubluhq
I think most ppl here only with older Holden's use PULP or higher grades of fuel. We eastern staters got rid of LRP a while back. And ULP you wouldnt go near unless you are desperate. Just add some valvemaster, Redex or Nulon upper cylinder lube and away
#16 Posted : Friday, 1 July 2005 1:08:13 AM(UTC)
Thanks John and Jason, I am looking at the hardened valve seats - am currently having a red SC head done so will find out how much extra it will be. It is 12 port with L34 valves.
Cheers, Rick
#17 Posted : Friday, 1 July 2005 6:16:08 AM(UTC)
maaaaate how much per litre do you pay ??
well mlcpete, your doing better than me !! We are currently at $1.36 a Lt for ULP and I wish we had 15,000 people her
"Such is life"
#18 Posted : Friday, 1 July 2005 7:30:02 AM(UTC)
BP supply all fuel in WA because Good News Geoff has decreed a special "cleaner" mix for our petrol and no one else in the world uses it except maybe some obscure Upper Slobbovian backwater.
So whatever brand you buy it's all BP. However the other compan
#19 Posted : Saturday, 2 July 2005 3:32:04 PM(UTC)
#20 Posted : Tuesday, 5 July 2005 11:12:55 PM(UTC)
Originally posted by Dr Terry
Hi Guys.
If only the silly government would make ethanol compulsory we wouldn't have s
Edited by user Wednesday, 6 July 2005 3:21:08 AM(UTC)  | Reason: Not specified
Guest (10)
3 Pages123>
This page was generated in 0.091 seconds.
