#1 Posted : Wednesday, 22 June 2005 6:54:47 AM(UTC)
Wanted one set NOS hq - hz door handles
#2 Posted : Thursday, 23 June 2005 1:07:13 AM(UTC)
Rare Spares has just received the first off-tool sample of this handle.It is being tested at present, the end appearance is A1.Once approved it is expected supply will be about August 05
#3 Posted : Thursday, 23 June 2005 8:58:15 AM(UTC)
Thanks Greg any idea on price and will they also fit LH torana
#4 Posted : Friday, 24 June 2005 12:03:41 AM(UTC)
Thanks for the enquiry,This is the application listing for the door handle OUTER HQ HJ HX HZ LH LX UC FRONT/REAR So you will possibly need 4 pieces per car ( 2 per coupe/ute).They come with the gaskets ( 2 on each handle bracket)Pricing is still to be con
#5 Posted : Thursday, 30 June 2005 3:27:37 AM(UTC)
Just an update on the progress:
There is a slight modification on the mounting plate to be made and then the handle is to be re-tested for fitment.Appearance has been approved so it is getting closer to completion.
Guest (5)
