#1 Posted : Tuesday, 28 June 2005 8:57:37 PM(UTC)
Hi Guys,
Just thought you might be interested in the Gemini Parts Sale that is on in the Online Shop at the moment; The sale ends 31st of July 2005, and is only while stocks last. Parts are as follows, you'll find the pricing in the Online Shop.
9941712 - ARM WIPER BLACK TX-TE GEMINI R/H & L/H
9947437 - NAMEPLATE "HOLDEN" TE ENDGATE / DECKLID
91081691 - BARREL & KEYS TD TG GEMINI VAN WAGON LH DOOR
92000331 - LAMP LICENCE PLATE TD
92015123 - TRIM/CAP WHEEL CENTRE SUIT STANDARD WHEEL TF-G
92015226 - OWNERS MANUAL TF GEMINI
92019628 - OWNERS MANUAL TG GEMINI
94215572 - ROD HOOD SUPPORT TF TG
94217323 - SEAL FUEL FILLER NECK PETROL ENG TE-F-G
8941026665 - CONSOLE REAR BLACK TF GEMINI
8942003831 - MIRROR PACKAGE INTERIOR GEMINI ALL
8942005246 - PANEL BONNET LOCK GEMINI TX
8942010062 - SPRING BONNET LOCK GEMINI
8942013501 - KNOB GEARSHIFT TX GEMINI 4 SPEED MSE TYPE
8942014991 - COVER BACK INTERIOR HANDLE GEMINI RIGHT HAND
8942016531 - PANEL REAR GEMINI SEDAN TX
8942027790 - SWITCH PARK BRAKE LAMP GEMINI ALL
8942028510 - SWITCH AUX DRIVING LAMP/HEATED REAR WIND SWITCH
8942070510 - SCREW HINGE & HINGES TO GLASS 1/4 GLASS TX GEM CPE
8942085080 - KNOB ASM TRANSMISSION CONTROL GEMINI ALL
8942092754 - SKIRT INNER FENDER RH GEMINI TX W/A8C TC TD
8942106040 - DOOR LOCK LHF GEMINI SEDAN
8942120960 - HORN LEAD & CONTACT ASSY TD TE 2 SPOKE S/WHEEL
8942141700 - BUSH UPPER CONTROL ARM REAR GEMINI ALL
8942141870 - SPRING BONNET CATCH TX - TC GEMINI
8942146591 - PANEL LOWER VALANCE TE,TF,TG
8942152212 - GRILLE VENTILATOR REAR 1/4 PANEL TE TF TG GEMINI L
8942174000 - GASKET TE FRT PARKER LENS TF FRT INDICATROR LENS
8942210750 - LENS NUMBER PLATE LIGHT TE SEDAN
8942249251 - DOOR SKIN REAR DOOR
8942277451 - FENDER GEMINI TF-TG RIGHT HAND
8942277461 - FENDER GEMINI TF-TG LEFT HAND
8942377522 - HANDLE RHF OUTER GEMINI SEDAN ONLY
8942384020 - BARREL $ KEYS TF TG GEMINI GLOVEBOX
8942548240 - GRILLE TF GEMINI
8944739430 - KNOB GEARSHIFT GEMINI 4 SPEED
94200891CY - ARMREST BLACK GEMINI ALL FRONT REAR L & R
HLA1013 - HEADLAMP ASSM TC L & R / TD TE ROUND L & R
LFT1044 - LENS FRONT INDC TX TC TD RIGHT HAND
LFT1052 - LENS FRONT INDC AMBER TF TG RIGHT HAND
LFT1063 - BUMPER BAR LIGHT GEMINI TE LEFT HAND
LRS1030 - LENS TAIL LAMP REFLECTOR TX TC TD SED TD COUPE R/H
LRS1031 - LENS TAIL LAMP REFLECTOR TX TC TD SED TD COUPE L/H
LRS1034 - LENS TAIL LAMP TX TC COUPE RIGHT HAND
LRS1036 - LENS & RIM TE SEDAN TAIL LAMP RIGHT HAND
LRS1084 - LAMP ASSM TAIL STOP TURN TD SEDAN COUPE LH
LRS1085 - LENS ASSY TX TC SEDAN TAIL LAMP LEFT HAND
LRS1086 - LENS ASSY TX TC SEDAN TAILLAMP RIGHT HAND
LSM1007 - LENS FENDER SIDE INDC TF'E'+'F',TG'E' LEFT HAND
LSM1008 - LENS FENDER SIDE INDC TF'E'+'F',TG'E' RIGHT HAND
M37727 - BOLT BATTERY TRAY MOUNTING
RRQS108 - SEAL REAR 1/4 WINDOW GEMINI COUPE LEFT OR RIGHT
VS14789 - SEMI SEALED BEAM TD GEMINI QUARTZ HALOGEN
WC1000 - TRIM/CAP WHEEL CENTRE SUIT STANDARD WHEEL TF-G
Fastlane Administrator
Duzty Offline
#2 Posted : Wednesday, 29 June 2005 7:29:44 AM(UTC)
Duzty
yeh they are VERY VERY good specials.
#3 Posted : Tuesday, 26 July 2005 7:34:59 PM(UTC)
It looks like Rares may be getting out of the Gemini market with these specials I hope not I still need some stuff
#4 Posted : Monday, 8 August 2005 6:10:19 AM(UTC)
get in quick
#5 Posted : Monday, 8 August 2005 9:49:55 PM(UTC)
how much do you whant for it
#6 Posted : Tuesday, 9 August 2005 4:41:59 AM(UTC)
can you do the same for HKTG parts? ;P
#7 Posted : Wednesday, 10 August 2005 4:02:15 AM(UTC)
les Offline
#8 Posted : Thursday, 11 August 2005 9:16:51 AM(UTC)
les
I will have a look at what we can put on special for HK HT HG models in the next few days
#9 Posted : Tuesday, 6 September 2005 4:04:58 AM(UTC)
Hey im looking for a clutch cable for a 81 TE Holden Gemini
#10 Posted : Tuesday, 6 September 2005 7:45:24 PM(UTC)
Try the online shop, top right of the screen.
Description: CLUTCH CABLE TX-G GEMI W/1.6 PETROL ENG Product Code: 92017393 Price inc GST($AUD): $58.63 EA
Guest (6)
