Just got back from Pickles auctions they sold a 93 Calais for $250 or $350 I missed the exact figure. It had been burnt out mainly in the cab the engine bay was burnt but a light burn only the plastics was damaged and the wiring,the aluminium was ok. So for $350 or whatever a reasonable injected motor all you need to do is get the computer and wiring harnews and plastic bits sorted out. You would be able to sell the diff and rear doors and boot, and the rest to the scrappy you would get a few bucks there also.
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
wow that is very cheap,either a v6 or v8 can still use alot from the car.
Sorry should have said . It was V8.
Anyway hte 6s with a fairly minor boot in the bum or front fender bender go for around 600-800.
