#1 Posted : Saturday, 16 July 2005 4:27:23 AM(UTC)
dose anyone know if it is possible to make or buy replacement fuel lines from pump to carby. I would like to keep original if possible.
Craig
ozjason Offline
#2 Posted : Saturday, 16 July 2005 5:14:30 AM(UTC)
ozjason
Craig,
Definitely possible. I discovered a leak with mine recently. Common advice was to find one at a wrecker... I didn't want to do that, as they are also 30 years old. Went to my local mechanical shop (can recommend them if you are in Brisbane),
GMH1975 Offline
#3 Posted : Saturday, 16 July 2005 5:00:32 PM(UTC)
GMH1975
You used to be able to get steel fuel line from repco.
I think they call it bungy tubing or something along those lines.
If you have a pipe flarer you can do it all yourself.
I had to use it to makea return line for my efi setup in my HX.
Ifrepco no l
Not the BLOODY Kingswood
#4 Posted : Wednesday, 27 July 2005 11:02:16 AM(UTC)
thanks for the help, found the fittings at pirtek
