RussVRute Offline
#1 Posted : Tuesday, 19 July 2005 6:21:16 AM(UTC)
RussVRute
G'day All,
I remember seeing somewhere in this forum about putting commodore rack and pinion steering into an HQ-WB, does anybody know if this is a simple swap or whether welding and major work is involved(I cant weld for s**t)and what model commodore steering setup is best to use? I would love to do it to the tonner, anything has to be better than the armstrong steering system!!! Any advice greatly appreciated. Thanks. Russ.
#2 Posted : Tuesday, 19 July 2005 7:25:28 AM(UTC)
A Mate of mine is working a set out for the HQ-HZ. you have to do another set of lower control arms move the area where the lower control arms bolt to on the chassis foward,notch the back section of the sump, its really busy, When he gets this done, drive
#3 Posted : Tuesday, 19 July 2005 9:05:34 AM(UTC)
There is a member on here who has done a rack & pinion arrangemnt (and a very neat front shock/spring arrangement) in the front of a Monaro.
He has done heaps of work that would be beyond the scope of a DIY who is not proficient in welding, but it beat
peter_flane Offline
#4 Posted : Tuesday, 19 July 2005 9:13:09 AM(UTC)
peter_flane
Rods Racks and Suspension is a pretty good setup in my opinion. I have one in the EH and it is great. It is rear mount. Have a look at his website www.rodsracks.com.au
#5 Posted : Tuesday, 19 July 2005 9:16:49 AM(UTC)
Edited by user Tuesday, 19 July 2005 9:19:59 AM(UTC)  | Reason: Not specified
peter_flane Offline
#6 Posted : Tuesday, 19 July 2005 10:39:23 AM(UTC)
peter_flane
Rods Racks uses LH-UC Torana rack for front mounted. You may consider this type of rack? Maybe this is not physically possible?
Taz2 Offline
#7 Posted : Tuesday, 19 July 2005 4:20:22 PM(UTC)
Taz2
Not sure if Mick is refering to me or not, but I have done a rack & pinion steering set up for my HQ GTS Coupe.
I've used a VH Commodore steering column, VH manual rack with Torana tie rods and ends.
Rack bolts onto mounts welded to the rear of the engi
In thrust we trust
#8 Posted : Tuesday, 19 July 2005 8:55:30 PM(UTC)
