#1 Posted : Wednesday, 20 July 2005 6:03:03 AM(UTC)
Looking at fitting under dash A/C to the HQ & want to keep it original, so I want to know if the same compressor mounting bracket are used on all sixes, including blue & black motors???.
Thank's kevin
#2 Posted : Wednesday, 20 July 2005 6:20:24 AM(UTC)
Hi Kev,
I think there are some different brackets for the aircon compressors depending on model (both car and compressor).
I have a combined alternator/aircon bracket on the Qute for sale. It can be seen at http://gallery.oldholden.com/Qute on page
Edited by user Wednesday, 20 July 2005 6:24:46 AM(UTC)  | Reason: Not specified
#3 Posted : Wednesday, 20 July 2005 7:46:08 AM(UTC)
fitting the underdash unit won't be original anyway. The black motors have boltholes in the right side of the ehad so the compressor bolts there.
#4 Posted : Wednesday, 20 July 2005 7:13:37 PM(UTC)
Parkridge wreckers in Brisbane have an HX with air, the engine compartment stuff is the same as HQ, missing original relay though and HXs also have extra wiring for thermo fans.
arren
#5 Posted : Thursday, 21 July 2005 4:10:35 AM(UTC)
John, I have the original dealer fitted, in dash unit which replaces the glove box, but basically it is an under dash unit, but the one I got was out of a V8 so the compressor mounts are wrong for the 6.
Warren, I take it that the same bracket is used
#6 Posted : Thursday, 21 July 2005 4:31:30 AM(UTC)
Hi Kevin,
I just noticed that you are in Victoria.
I am working in Melbourne ATM and, if you want it and we come to an agreement, could bring it back with me next time I go home to Perth (in about 3½ weeks).
Cheers...Dave
mackv8 Offline
#7 Posted : Thursday, 21 July 2005 7:15:27 AM(UTC)
mackv8
I all so have the bits are from a hz are still on the motor parts are in melton if qute cant help you. thanks al
Edited by user Tuesday, 3 May 2016 3:39:25 PM(UTC)  | Reason: Not specified
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
#8 Posted : Friday, 22 July 2005 2:10:32 AM(UTC)
Thank's Qute & mackV8, but I just found a wrecker with a full set up (intergrated A/C) in a HQ with a red 6, the car is very rusty & is to go for crushing next week & luckey for me $50 got all I wanted off it, also had the remote boot release & front over
#9 Posted : Friday, 22 July 2005 3:16:04 AM(UTC)
Hi Guys.
The 6 cyl Frigidaire/Harrison/Delco A6 a/cond compressor brackets are the same from HQ up to the release of the Commodore.
The HQ-HZ type (also LH/LX/early UC) has the belt adjusted by swinging the compressor.
The Commodore (both red & b
peter_flane Offline
#10 Posted : Friday, 22 July 2005 9:22:56 AM(UTC)
peter_flane
The VK motor in the limo has Sanden air compressor bolted to the Drivers side of the head. As Terry says adjusted by idler pulley.
Guest (6)
