#1 Posted : Sunday, 24 July 2005 7:10:49 PM(UTC)
anyone know if these lift off after the screws are undone, or are tehy welded to the chassis at a particular area..., wanna lift my cab up and off to clean up the chassis good and proper, but cant find this info on the net, and dont have a gregorys manual yet!
thanks
#2 Posted : Sunday, 24 July 2005 8:52:21 PM(UTC)
AFAIK there's no welding there on utes/vans/tonners only the bolts (someone correct me if i'm wrong), would be a good chance to fit new rubbers too. if you look through the www.oldholden.com sheds area (link on top RHS of the site's front page) there are
#3 Posted : Sunday, 24 July 2005 11:08:36 PM(UTC)
that site doesnt seem to be working on anything but the front page :(
i really need to get a gregorys manual!
#4 Posted : Monday, 25 July 2005 2:05:01 AM(UTC)
it'll work sooner or later some updates are being done. but yeah a workshop manual would help. ;)
classic oz wreck Offline
#5 Posted : Monday, 25 July 2005 5:06:40 AM(UTC)
classic oz wreck
they do lift off after undoing the bolts,you will find these thru the holes in the chassis underneath..plus the 2 at the back of the cabin that holds them to the chassis brace...
www.classicozwreck.com.au
#6 Posted : Monday, 25 July 2005 7:03:40 PM(UTC)
When you get the cab off you will probably find the chassis is rusted under the body mounts. This is easy to fix. Clean all the rust off, and weld some big gal washers directly onto the chassis - if memory serves me correct they are 24mm (check first). Th
