#1 Posted : Tuesday, 26 July 2005 12:18:18 AM(UTC)
Hi,
The tail lights on my EL are not working and my cruise control does not kick off until I press REALLY hard on the brakes. Will an auto electrician be able to fix this? Or just a mechanic? I have checked fuses etc also.
Thx,
Nikki
dave351cid Offline
#2 Posted : Tuesday, 26 July 2005 6:23:22 AM(UTC)
dave351cid
it is proberly the brake light switch on the brake pedal that is playing up. this works both the lights and the cruise cotrol.
might even just need adjusting.
if you look under the dash where the brake pedal sits normally you should see a switch wi
old B`s go hard .
new B`s have air.
#3 Posted : Thursday, 4 August 2005 10:25:55 PM(UTC)
yer id say it's the brake light switch, iv seen a holden one melted from having the braks on too long in a traffic jam, but thats what you get with holdens!!
#4 Posted : Friday, 5 August 2005 8:49:13 PM(UTC)
Hi,
Thanks guys, yes it was the brake actuator (forgive the spelling) cost $38 dollars for an auto electrician to replace it.
Thx,
Nikki
This page was generated in 0.160 seconds.
