#1 Posted : Wednesday, 27 July 2005 5:49:07 AM(UTC)
Ive got three questions
1. Can I use a pre EFI cam or do I have to run a VN onwards cam when you put VN heads on a RED 308.
2. Do you have to change the push rods or can you use the Red motor push rods.
3. Does the Red motor rocker gear bolt onto the heads.
4. Where is the best place to get a reasonably priced performer manifold to suit the conversion.
Any info would be appreciated.
#2 Posted : Wednesday, 27 July 2005 6:35:38 AM(UTC)
I can answer one or two of your questions Reece.
You HAVE to use a cam for the EFI heads as the valves are in a different order to the carby heads.
Check out Harrops for the intake manifold (there are a couple of others but I cant remember who they
#3 Posted : Wednesday, 27 July 2005 6:35:38 AM(UTC)
Check out Harrop's for the intake manifold (there are a couple of others but I can't remember who the
#4 Posted : Wednesday, 27 July 2005 6:56:22 PM(UTC)
Redline make a decent valley cover. They are John Cain's old castings, and fits under the bonnet in a Commodore. Not sure about pushrods, but I think the rocker gear is the same, but check first.
#5 Posted : Wednesday, 27 July 2005 6:56:22 PM(UTC)
Redline make a decent valley cover. They are John Cains old castings, and fits under the bonnet in a Commodore. Not sure about pushrods, but I think the rocker gear is the same, but check first.
#6 Posted : Wednesday, 23 April 2008 1:07:26 AM(UTC)
I got 1 answers for you Reece.
1.Your a fag
That is all.
This page was generated in 0.066 seconds.
