G'day All' Getting a motor with hardened valve seats this weekend, so no more lead replacement additive, YAHOO!!, what I need to know is are there any benefits to putting in a catalytic converter other than the pollution issue?(which I might add is a very good one, because even though I am not a "greenie" as such I am environmentally aware and dont like to make more pollution than necessary) and are they expensive, and do they affect power? just thoughts going round my head I guess, dont know if I will do it, just need some feedback from people more in the know than me. Cheers. Russ.
Russ,
You'd only need a cat if you put in a new era motor, say a GENIII or Commo V6/V8 from a VN onward. Anything of the pre-unleaded days can go without a cat. They are expensive, very. They rust out quick as the conversion process just produces a lot
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
There is a major health benefit with having a functional catalytic converter, and that is is reduces aromatic hydrocarbon emissions from the exhaust ie Benzene, Toluene etc., which are very high on the carcenogen 'list'. However, putting in a secondhand o |
You will also find that once a cat is dead......they do recycle the innards of it, so that is also another plus I guess. There are some precious metals to be recovered.
John
When you will need a cat on a HQ-WB is if you use a VL or later engine block. |
If you love the ones around you and you work on the running car in the garadge then you should run the cat ( no cancer wanted here so I use them ) and you can get good Hi Flow units these days and what price can you put on health?? Cheers Jim
Yes what Jim said.
They don't seem to affect the performance of your car if you pick one big enough.
My Falcon's cat dropped it's guts & blocked the exhaust almost completely a few years back. To get me going I removed it & shook out all of the loo |
