edmundo Offline
#1 Posted : Sunday, 31 July 2005 7:40:41 PM(UTC)
edmundo
gidday guy's
my old 186 is spittin and chuggin running on unleaded and the mixture, any suggestions. i will be get my valve's and heads done for the unleaded in the near future.
thanks
#2 Posted : Sunday, 31 July 2005 7:50:13 PM(UTC)
Im using unleaded in my 202, no dramas with flashlube/unleaded mix.. maybe you need to clean ur spark plugs or make sure everything in ur ignition system is functioning properly!! You might need to feed your motor a bit more fuel as unleaded is lower pow
peter_flane Offline
#3 Posted : Monday, 1 August 2005 4:10:25 AM(UTC)
peter_flane
Try premium unleaded
