#1 Posted : Wednesday, 3 August 2005 4:34:08 AM(UTC)
i want to put a vl diff into my hr i just want to know about how much it would cost to get the mounting brackets changed and axles changed to fit the 13" stud pattern and use my brakes
or should i put a volvo diff and just change the mounting brackets and tailshaft
i think the vl diff would be esier for parts and they are cheep to buy hole diffs
#2 Posted : Wednesday, 3 August 2005 10:25:42 AM(UTC)
volvo diffs should cost around $90 from most wreckers and are plentyful but 13" rims wont fit they are the same stud pattern but volvo's have disc brake rear that need at least 14" rims to clear the caliper also to fit a commodore diff you may need to hav
#3 Posted : Wednesday, 3 August 2005 3:57:21 PM(UTC)
Commodore rear discs also require a minumim 14" wheel.
The VC/VH 4 cylinder commodore diff had a drum rear with early holden/torana stud pattern if that's any help.
Jim Briar Hill Offline
#4 Posted : Thursday, 4 August 2005 2:06:25 AM(UTC)
Jim Briar Hill
Would it not also be to wide ??
#5 Posted : Thursday, 4 August 2005 2:23:30 AM(UTC)
thanks for the info ill look into it a bit more
peter_flane Offline
#6 Posted : Thursday, 4 August 2005 6:32:45 AM(UTC)
peter_flane
In my opinion if you are putting a VL diff in, you might as well spend the same money putting a VN onwards diff in. $150 second hand complete or $400 complete for LSD. Expect to pay $400 to get it shortened & converted including stud pattern changed to HR
