#1 Posted : Friday, 5 August 2005 2:16:25 AM(UTC)
i've had a good look and there are no seat belt mounts on the rear parcel shelf of my HK kingswood, however there are 4 factory lower seat belt mounts (with bolts), did holden only use 3 lap belts for the rear seat??? I am now considering buying rare spares seatbelts but want 2 lap/sash belts in the rear with one centre lap belt, anyone used these belts? has anyone installed parcel shelf seatbelt mounts in a HK sedan? are there any factory measurements?
Lastly did front bench seat models have 2 or 3 front seats + belts?
Thanks guys...
#2 Posted : Friday, 5 August 2005 2:41:04 AM(UTC)
Most Holdens that were factory fitted with seat belts and a bench front seat had a lap belt in the middle. I've drawn a blank on the rears (red wine again) in a HK, but I think they were only lap belts. I'll look at one of my Monaros tonight. I'm pretty s
#3 Posted : Friday, 5 August 2005 3:24:39 AM(UTC)
Hi Guys.
HKs didn't get factory rear seat belts at all, front 2 only. The rears weren't factory fitted until mid HG.
The ones you see have been dealer fitted or fitted at some time in the last 35+ years. I don't think it's compulsory to have rear se
#4 Posted : Friday, 5 August 2005 4:00:50 AM(UTC)
that would be great if you could let me know Byron, I want lap sash belts in the back as well as i have kids in booster seats...
I did think of the rear pillars but can't feel any mountings under the hoodlining there, where were the HG belts mounted? hop
#5 Posted : Sunday, 7 August 2005 12:43:53 AM(UTC)
My HK Kingswood sailed through a Safety Certificate inspection (in Qld) with only the 2 belts for the outboard front seating positions, Dr Terry is correct, I believe.
#6 Posted : Sunday, 7 August 2005 12:56:18 AM(UTC)
i want rear belts for my kids...anyone recommend a good engineer in SEQ?
wayne Offline
#7 Posted : Sunday, 7 August 2005 2:09:18 AM(UTC)
wayne
check under bottom of hood lining if memorey is correct you dont need engineer if they egsist factory
and i think they do
First
On
Race
Day
#8 Posted : Sunday, 7 August 2005 2:14:20 AM(UTC)
thanks mate will go and have a look right now...
#9 Posted : Sunday, 7 August 2005 9:18:26 PM(UTC)
Removed the fibreboard rear parcel shelf panel, stuck my hand up behind the hoodlining, looked up through the boot...no upper mounts anywhere...
wayne Offline
#10 Posted : Sunday, 7 August 2005 10:08:16 PM(UTC)
wayne
locate where hole for anchour bolt should go get nut welded in only engineer i know is ray cross in northern nsw ballina area otherwise try yellow pages show them when fitted all should go smoothly
hope this helps
First
On
Race
Day
Vintage Caravans Offline
#11 Posted : Sunday, 7 August 2005 10:43:10 PM(UTC)
Vintage Caravans
HHHHmmmm SE Qld engineer,
Try Tony Lye great bloke and he is switched on with Old Holdens, he is located northside of brisbane from my memory I will send you his number (so as not to publically list it without his permission)
Failing that Queensland Tr
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
#12 Posted : Thursday, 11 August 2005 11:03:27 AM(UTC)
On a kind of related topic, does anyone have any experience with baby capsules in the front seat of a van/ute? I have buckets in my HQ and have been told you can get an engineer to rig up a baby seat in the middle. I'm also contemplating putting a bench s
#13 Posted : Thursday, 11 August 2005 5:43:43 PM(UTC)
baby capsules aren't usually reccomended for front seats but AFAIK it's not illegal, our baby seats had two options...forward facing and rearward facing (depends on age of kid) both ways of fitting required (at least) a lap belt to hold the capsule down o
#14 Posted : Thursday, 11 August 2005 11:28:17 PM(UTC)
Edited by user Thursday, 11 August 2005 11:29:27 PM(UTC)  | Reason: Not specified
#15 Posted : Monday, 15 August 2005 7:40:19 PM(UTC)
Thanks for the info guys. Seems like an odd sort of topic I'll have to do a bit more research into. (Ive got about 6 months!) Cheers.
#16 Posted : Wednesday, 17 August 2005 6:16:19 AM(UTC)
If u r in Brissie a place called VANQUIP will do the job. I just had 6 belts put in an fc. they did a really good job and managed to hide the mounts for the drivers and passengers inside the pillar. there's nothing worse than a big hex head bolt on the
#17 Posted : Wednesday, 17 August 2005 7:57:55 AM(UTC)
Thanx Chris. Im in Melbourne but. Cheers.
