#1 Posted : Sunday, 7 August 2005 12:29:56 AM(UTC)
Hello Everyone,
Im wondering if a V6 Commodore diff would be able to handle the output of a standard Holden 235 V8. Im building an Austin A40/HQ Holden based ratrod and am using HQ running gear including the ute chassis,I have a Commodore disc brake conversion kit for the front end and would love to use the Commodore disc's and stud pattern on the rear also. Yes I know I could but the V8 Commodore diff but I already have a good VP V6 Commodore diff that I want to use if possible.
Regards
Owen and Ned.
God is Dog spelt backwards.
#2 Posted : Sunday, 7 August 2005 12:37:35 AM(UTC)
Hello Owen its Owen again,
One letter makes all the difference it should read " yes I know I could buy the V8 Commodore diff
Sorry Owen.
#3 Posted : Sunday, 7 August 2005 2:10:59 AM(UTC)
i can't see why not, the V6 would have more power than a stock 253(?) there may be advantages in using a V8 diff only if you're a hoon ;)
#4 Posted : Sunday, 7 August 2005 3:27:06 AM(UTC)
Thanks 70 Ute,
No my hooning days are over, actually I never started.
Good news now I can have 4 wheel disc brakes and Commodore rims.
Regards
Owen.
#5 Posted : Sunday, 7 August 2005 6:38:48 AM(UTC)
hey Owen a fellow rodder,, luv a rat ride im part way through a forty rat pickup build, its v8 is coupled to a 4cyl diff via a 6 cyl powerglide a lot of research has gone into this set up( i have faith it will work??) my HJ munroe has 4 wheel discs on a
Munromad2004 Offline
#6 Posted : Sunday, 7 August 2005 8:40:23 AM(UTC)
Munromad2004
I was reading somewhere just the other day (probably on here somewhere) and someone has listed the output of a 253 versus the later V6 and there wasn't much difference.
I reckon a V6 diff will handle a 253 quite confortably.
Although any diff will break
#7 Posted : Monday, 8 August 2005 5:47:38 PM(UTC)
The non-LSD V6 & V8 diffs are practically the same - just the V8 one got selected shot-peened internals.
The LSD V6 & V8 diffs (except Hydratrak) are identical internally.
You'll have no probs behind a 253, as the same diff (internally) was fitted beh
