3 Pages<123>
#21 Posted : Wednesday, 10 August 2005 6:21:48 PM(UTC)
1258 is the combination number for Kingston cream with ermine white roof, the reason you have not got these combination numbers Byron is that the only Monaro with two tone was HZ. These combination numbers exist for all external colour combinations.
W
#22 Posted : Thursday, 11 August 2005 5:22:23 AM(UTC)
yup clear as mud... But thanks for all the infoByron and Warren, I had a (quick) look on the steering box and column this morning but found no numbers, are they cast or stamped, which angle should I be looking?
#23 Posted : Thursday, 11 August 2005 6:07:36 PM(UTC)
Front left hand corner, stamped into the alloy, adjacent to the cast cover plate 9about 7mm high characters). On the column its yellow or white paint on the firewall side of the plate that bolts the column to the firewall (about 20mm high characters). If
#24 Posted : Thursday, 11 August 2005 6:07:36 PM(UTC)
Front left hand corner, stamped into the alloy, adjacent to the cast cover plate 9about 7mm high characters). On the column it's yellow or white paint on the firewall side of the plate that bolts the column to the firewall (about 20mm high characters). If
#25 Posted : Thursday, 11 August 2005 7:27:03 PM(UTC)
4L8, 4th November 1968!
Thank you very much for your help Byron.
#26 Posted : Friday, 12 August 2005 3:12:12 AM(UTC)
So thats what those numbers on the column mounting plates mean...Id always wondered...
Cheers...Dave
#27 Posted : Friday, 12 August 2005 3:12:12 AM(UTC)
So that's what those numbers on the column mounting plates mean...I'd always wondered...
Cheers...Dave
#28 Posted : Friday, 12 August 2005 6:36:01 PM(UTC)
If the box or column are original then they are within the ballpark of your build date, ie within a week or two, normally even closer. When you look closely you find these codes all over the car. Just remember that on the US sourced parts and on pre-1972
#29 Posted : Saturday, 20 August 2005 10:04:16 AM(UTC)
NEED TO KNOW WHAT MY HT UTE IS
CHASSIS NO HT 80180M
MODEL 21119B
LONG PLATE SAYS 80180TH161494
TRIM 1174 12A
PAINT 568 10958
THANKS GUYS ANY HELP WILL BE APPRICATED
#30 Posted : Saturday, 20 August 2005 11:07:00 AM(UTC)
Brisbane (Acacia Ridge) built HT 6cyl Belmont ute - as far as the plates are concerned. Body is a Dandenong (Melbourne) body. This means either its been rebodied, or the shell was constructed in Brisbane and the car put together in Melbourne. Will check f
#31 Posted : Saturday, 20 August 2005 11:07:00 AM(UTC)
Brisbane (Acacia Ridge) built HT 6cyl Belmont ute - as far as the plates are concerned. Body is a Dandenong (Melbourne) body. This means either it's been rebodied, or the shell was constructed in Brisbane and the car put together in Melbourne. Will check
#32 Posted : Sunday, 21 August 2005 5:17:49 PM(UTC)
Mate thanks for the info already,that would be great if you could check for me. Another question for you is i have a premier front end on should it have that or has the previous owners befor me added it on? did you have any idea on the paint codes at all?
#33 Posted : Tuesday, 23 August 2005 1:46:40 AM(UTC)
1174 is Pinaroo beige. 12A is Morocco red vinyl, bench seat.
#34 Posted : Wednesday, 24 August 2005 6:53:02 PM(UTC)
Shane, your depiction of the chassis number threw me. HT80180M is the body number, which also happens to be a valid chassis number for a Melbourne HT (albeit probably a bit high) . As a body number it means:
HT - HT
8 - Holden
01 - 6cyl Belmont
80 -
#35 Posted : Friday, 26 August 2005 4:14:26 AM(UTC)
Is any of the code data available on the web or in a book somewhere readily available? Would be quite handy to be able to look up the codes of your car on the net, with a database, expert system or the like.
#36 Posted : Friday, 26 August 2005 7:18:03 AM(UTC)
Thank you so much for the infomation you have given it is much appricated
#37 Posted : Tuesday, 6 June 2006 5:21:20 AM(UTC)
i am after the paint and trim colour for these codes
PAINT 568-10978
TRIM 1184-11A
CHEERS!
#38 Posted : Tuesday, 6 June 2006 7:35:35 AM(UTC)
1184 is Pharoah Gold paint. 11A is Anique Gold trim.
#39 Posted : Thursday, 15 June 2006 6:33:04 AM(UTC)
just wanted to know colors of these codes
trim 1824-30x and paint 568-13138
there off a hq coupe,cheers
#40 Posted : Thursday, 15 June 2006 6:51:57 AM(UTC)
Hi eyrie73.
The exterior paint is Salamanca Red & the interior trim is 73 GTS Black Vinyl.
Dr Terry.
3 Pages<123>
