#1 Posted : Monday, 12 July 2004 8:22:43 PM(UTC)
Hello,
I have aqeustoon about carb size. My 308 engine is relatively stock with extractors, single 21/2" exhaust and a mild cam. No head work has been performed. The car is manual and has quite high gearing (diff = 2.75:1) I want to install a holley carb. Is a 600CFM too big ? The info I've read on carb sizing seems to indicate a 390CFM would be the size. Any advice welcome.
#2 Posted : Monday, 12 July 2004 8:36:11 PM(UTC)
Why not stick with the quadrajet, Holden got the carb right on the 308s, they can't be beaten if setup properly!!
Peter
#3 Posted : Monday, 12 July 2004 11:53:51 PM(UTC)
The original carby, the quadrajet, is a 650CFM so 600 should be fine.
I would agree with Peter, Quadrajets are good carbies if you take the time to set them up.
Warren
#4 Posted : Tuesday, 13 July 2004 12:17:07 AM(UTC)
stick with the quaddie.mine runs like a dream day in day out
This page was generated in 0.095 seconds.
