Evil Homer Offline
#1 Posted : Monday, 15 August 2005 4:44:40 AM(UTC)
Evil Homer
Hi All,
I'm hoping you can help me decipher the ID plates on my HT Premier
Body ID RHS:
BODY HT81169M-00713B
TRIM 1178-12B
PAINT 567-11206
INSERT (blank)
TOP (blank)
Long plate on top LHS:
81169TH132330
Firewall Stamping:
HT00808B
From the last time it was in rego it was a 69 HT
thanks
#2 Posted : Monday, 15 August 2005 6:50:25 PM(UTC)
This is a very early HT Premier from the Brisbane plant. The tag itself is an HK tag as the HTs do not have the insert on them. Only the Brisbane plant stamped HTs on HK tags. The car was built when the HK was still in production so i would say a 5/69 bui
#3 Posted : Tuesday, 16 August 2005 3:57:45 AM(UTC)
Was thanked: 603 time(s) in 570 post(s)
Warren, very early Pagewood HT's also had HK body tags. HT with the chassis number HT00008SS has a HK body plate with 80437TR-00001-H5. Apparantly a few other 'number 1' Pagewood HT's also used HK plates.
#4 Posted : Friday, 19 August 2005 7:19:11 PM(UTC)
Evil Homer, check your body plate. I think the trim code of 12B should be 12R.
#5 Posted : Monday, 22 August 2005 6:25:07 PM(UTC)
Yes I also know of an Adelaide car HT on an HK tag but they also have HKs on HT tags. But the car I saw was a prototype.
What I was indicating was the run of the mill stuff, a bit like the VNs with VL identification makings.
Warren
#6 Posted : Tuesday, 23 August 2005 1:03:47 AM(UTC)
Apparantly some late HK's (not sure which plant(s)) got HT style tags too.
#7 Posted : Monday, 30 January 2006 10:55:46 PM(UTC)
Byron my last HK had HT style tags from Melbourne.
Mine was the last HK made
Dave
#8 Posted : Tuesday, 14 February 2006 4:43:51 AM(UTC)
Hi All,
I recently brought a HT Monaro. Missing the VIN and Body I.D. tag. I have the fire wall number still stamped on it. It is HT27967B. If anyone can tell me how I can track down the Body I.D tag no's etc. I need to know the Body Number, Trim Number
#9 Posted : Tuesday, 14 February 2006 5:57:26 AM(UTC)
hi, I have some info that might be of help to you.
HT81169, is L6 Engine for premier sedan.
Vin Codes work out to be: vin number
81 - Is the series number.
1 - holden L6 Engine
69 - Is the year Built
T - Is the last letter of the model
H1 - Assem
This page was generated in 0.092 seconds.
