#1 Posted : Monday, 15 August 2005 9:10:53 PM(UTC)
I recently bought a 69 Torino. Guy I bought it off of said it had a 351C out of an old Merc in it....but I am not sure it is, how can I tell for sure it is a Cleveland?
Munromad2004 Offline
#2 Posted : Monday, 15 August 2005 11:03:49 PM(UTC)
Munromad2004
Post the engine numbers for us and we'll take a look
Paul351xb Offline
#3 Posted : Tuesday, 16 August 2005 10:50:30 AM(UTC)
Paul351xb
Easiest way to tell a Cleveland from a Windsor is by looking at the thermostat housing. Cleveland thermostat is in the block while the Windsor is in the water pump.
Paul351xb Offline
#4 Posted : Tuesday, 16 August 2005 10:52:46 AM(UTC)
Paul351xb
or was the Windsor thermostat in the inlet manifold?? Never try to think and type when tired. Anyway Clevo thermostats are in the block. Jeeez that was harder than it had to be.
#5 Posted : Tuesday, 16 August 2005 11:35:10 PM(UTC)
Yep the Windsor has the thermostat in the inlet manifold.
XB351 Offline
#6 Posted : Thursday, 18 August 2005 4:13:25 AM(UTC)
XB351
Cleveland has the thermostat housing on the block.
#7 Posted : Thursday, 18 August 2005 6:30:36 PM(UTC)
Thanks, the only numbers I can find are on the intake, 13726548 and DOAE 9425-M I will look at the thermostat.
#8 Posted : Thursday, 18 August 2005 6:36:27 PM(UTC)
Ok, found the thermostat, just in front of the distributor cap, going into the block. I was begining to worry some about what I had. Now, any suggestions on a good setup to build it? Going to be used for street, nothing radical, but want to have efficient
Paul351xb Offline
#9 Posted : Thursday, 18 August 2005 10:23:58 PM(UTC)
Paul351xb
Is the engine a runner or does it need a rebuild? If the engine is fine, just put on a set of extractors ( headers ), maybe a mild cam. What sort of carby are you running? You can spend as little or as much as you want. It just depends if you are want
#10 Posted : Saturday, 20 August 2005 12:38:28 AM(UTC)
Engine runs, needs new wiring harness, old one corroded bad, shorts in it i.e. tail lights on all the time, no head lights ever. But does run. Guy I bought it off of had 2bbl intake with 2 to 4 adapter with worn out holly 650 on it. Been thinking new edlb
Paul351xb Offline
#11 Posted : Saturday, 20 August 2005 3:24:04 AM(UTC)
Paul351xb
Well at least you are in the States, you should be able to pick up a new harness easy enough I am guessing. They are the same as a Mustang one aren't they? Flick the 2 barrel manifold and get a 4 barrel one if you don't end up supercharging the engine.
#12 Posted : Friday, 2 September 2005 12:50:25 PM(UTC)
Lost remote for falcon xr6 smartlock. What now? HELP from Zimbabwe
Paul351xb Offline
#13 Posted : Saturday, 3 September 2005 2:45:58 AM(UTC)
Paul351xb
Might be an idea to give your local Ford dealer a call. I know they sold the Falcons through Ford in South Africa so a replacement remote should not be too hard for you to get. I quite often see second had ones come up on www.ebay.com.au but I have no
wayne Offline
#14 Posted : Saturday, 3 September 2005 3:52:26 AM(UTC)
wayne
tells you in the frount of the handbook how to reprogram it to your car
or ask a ford tecnition to do it if you buy new
First
On
Race
Day
Guest (5)
