#1 Posted : Tuesday, 23 August 2005 4:32:10 AM(UTC)
please help, my EB2 has become somewhat gutless, today on the drive home a mitsubishi galant, beat the **** out of me, from the mark and down the straight, the car still seems to have more balls than a 4cyc, but it just does not get up and go like it used to, i remember a time when on a slightly damp road, dropping it into 2nd and planting it would get the 265 wide tires spinning, now all it does it pull away slowly, i have done only one mod, the intake is now a POD filter not the ****ty air box, and i have had the leads replaced with 8mm leads from auto\bahn, not cheepy ones, and it has also since had a 2 1/2 sports exhaust on it. i mean come on my mothers ea, 3.9 carby beats my 4.0 MPFI!!!!!!! PLEASE HELP ME
EB2 Fairmont stage one shift kit, K&N intake, dumped on her nuts all over, 265's on the rear on simons 2 piece racing rims, 2 1/2" exhaust, pacemaker extractors, and hi flow cat. clarion headunit, kenwood front splits, kenson 300w 6x9's boss 1200 amp powering 2 jensen 600W 12", and alpine v12 amp powering speakers.
#2 Posted : Wednesday, 24 August 2005 6:08:02 PM(UTC)
how old is the engine?maybe its getting low on compression?
#3 Posted : Wednesday, 4 January 2006 11:10:41 AM(UTC)
well it is a 1993 EBII, with the original motor. it was owned by an old man before me and has had all it's services kept up to date. would a blown but repaird head gasket have anything to do with it? cause it happened and i had it repaired, but she is sti
#4 Posted : Wednesday, 4 January 2006 11:29:17 AM(UTC)
take in to your local mech and get him to have a proper look at it and he should be able to tell you where it is going wrong. is it starting ok or is it pretty rough.
HORSE'S FOR COURSE'S!!
#5 Posted : Wednesday, 4 January 2006 10:21:03 PM(UTC)
nothing unusual about the start, turns a few times than fires right away. and runs nice and smooth, ARRRGGGHHHH stupid car, more headaches than i really need or want.
#6 Posted : Thursday, 5 January 2006 6:33:31 AM(UTC)
Does your auto sound like its slipping? or has it been rebuilt?
Matt
#7 Posted : Sunday, 8 January 2006 5:46:58 AM(UTC)
It's possible the cam timing may be out by one tooth when they did the head gasket ?? worth getting checked, car will run ok but lack guts down low..
colcam
#8 Posted : Sunday, 8 January 2006 8:23:17 AM(UTC)
Sounds like base ignition timing may be out a few degrees,something else that can cause problems is cat convertor may have melted down causing too much back pressure.
if it ain't broke we can improve it.
#9 Posted : Sunday, 22 January 2006 9:15:47 PM(UTC)
Could it be your catalytic converter failing?
#10 Posted : Friday, 6 July 2007 5:30:10 AM(UTC)
how long since the injectors have been cleaned?
#11 Posted : Saturday, 7 July 2007 8:08:35 AM(UTC)
start with the basics, how long since the fuel filter was changed? maybe ck your fuel presure could be down i was going to say get the computer cked out by ford dealer on there test machine but if it has been modified it may not pick up (unsure if that is
Guest (11)
