#1 Posted : Saturday, 27 August 2005 3:30:16 PM(UTC)
Can anybody advise me if there is any problems with putting a V6 in my Hj. I was looking at a mtor and auto out of a VN , i have 3.08 diff ratio , would this be ok , and what sort of a setup is there for speedo conection.
Dwayne
Taz2 Offline
#2 Posted : Saturday, 27 August 2005 4:31:01 PM(UTC)
Taz2
As far as the ratio is concerned you are fine. That is the default ratio used in a VN :-)
I know a couple of people who have done this conversion, and they are happy with the end result.
Engine mounts are of course different. Pat Gardiner ( http://www.v
In thrust we trust
#3 Posted : Saturday, 27 August 2005 5:10:39 PM(UTC)
Hi Guys.
If you're using the VN/VP type auto it has the same threaded speedo cable fitting as the TH400 & TH350, so use the factory HQ-HZ TH400/350 cable.
Having said that, what you then have to do is do get a speed sensor (for the EFI ECU) fitted i
