#1 Posted : Monday, 29 August 2005 9:27:39 PM(UTC)
hi , i am wanting to fit power steering to my xd ute , it is a 6cyl with column manual , i was told that this is not a bolt on job as manuals never came out with power steer, can i just use the power steer rag flex joint and bolt it up? or is there some kind of modification that needs to be done ??, i really want to lighten up the steering , thanks
wayne Offline
#2 Posted : Monday, 29 August 2005 10:55:40 PM(UTC)
wayne
should be the same make shore you have all the lines clear of the manual rods.
First
On
Race
Day
ZC-Cruiser Offline
#3 Posted : Friday, 2 September 2005 5:37:27 PM(UTC)
ZC-Cruiser
get the box, pipes and pump from an XF - it should bolt right in
the steering shaft centre shaft will bee too long but it can be carefully tapped up to shorten it...
It's good to honk in a Henry
This page was generated in 0.161 seconds.
